RPM gauge and manual trans
252 views 1 reply 2 participants last post by  plinker17722
The auto-trans was converted to a manual trans by previous owner in my 1987 190D.
The rpm gauge is not working.
Watching this video, the rpm gauge is working with a manual trans 190D.
Anyone have an idea as what to look at to get the rpm gauge to start working?
But they do work , but maybe not as it should . You say you changed the box to manual ...What about the flywheel and CPS ? ...same thing on my '87 190d--and I went thru all the same items, it turns out to be the "klima" relay(behind the battery). I replaced it with a used one and tach started working --for a while, (like 2 weeks) then it only "sometimes works", so I swapped the orig. klima back, and it works again, now it's been ok for 5 weeks-I suspect the contact (s) in the recp./plug.(poor contact)
