Hello all,I want to apologize in advance for the length of this post but I figured I give u guys as much info as possible so I am experiencing a rough shaky start on my W212. Before buying this car for a little under market value at 94k on odometer (I now have 116k) , I did extensive research on the engine numbers dealing with that issue and I found an engine that was made after the “fixes”. The production date was May 2013 and engine 30 466xxx which already had updated check valves and tensioners. The problem is that I just started experiencing a rough shaky warm start after sitting for at least 5-10 mins. It shakes like it’s about to stall out along with some loud rattling for about 3-4 seconds. In the morning during cold start, I get the normal engine noise but I don’t NEVER once got the timing chain rattle and engine shake/ stalling feeling. Seems to only happen when engine is cooling down and not COMPLETELY COLD
After reading, I saw that there are some cases where the issues still happen after the “fix” production dates. I recently did an oil change which was about 1100 highway miles overdue and the noise is still there. I also read that pressing the brake pedal a few times and holding it during starting helps reduce the rattling and it does but does solve the problem. I am thinking of purchasing an extended warranty to have the issue fixed.
I want to pull the timing covers myself but the whole process of throwing parts at it isn’t something I wanna do. I wanna just pinpoint the problem and get it fixed but I know I can’t do cam adjusters on my own. So my question is do I purchase the Endurance warranty (I think that’s the best one I saw so far) before the CEL comes on and have them deal with the breakdown and fix? I posted a picture of what’s covered under their sample contract and it shows timing chain and gear and camshaft so it seems they would cover everything dealing with the timing right? ORRR do I start with removing the timing covers and doing some work myself?
Sorry again for the lengthy post and thanks in advance guys. I will try to get a video up of the noise
