1 - 8 of 8 Posts
  • After 3 miles it has a sudden and rough down shift. Only noticed on one road taken 2 times per week.
  • Normal for 4 matic?
  • 45000 miles atf135fe. First atf change not yet done
2014 E350 Sport
Speed is 30 mph going up hill
Yes, I've had the same problem. Typically happens when downshifting from 5th to 4th or 4th to 3rd - and as you noted only when going up hill at about 30 mpg. Also typically happens when engine is cold. Suggest you make sure car does not automatically upshift to a gear that is too high for speed. Watch the tach. If <1750 rpm you should force downshift with paddle
2014 E350 4Matic - Palladium Silver, Sport , 18k miles........
Just MTBW - but you are 5,000 miles past the recommended ATF service. I would have the service done and re-evaluate the shifting.
All I know is that for 2014 My E350 require the B service at 40,000 miles which includes Transmission service.
1 - 8 of 8 Posts
