2014 ML350 BlueTec
Would anyone happen to know, if 99 ML 430 rotors would fit on a 02 ML 55 ?????? l have the set of Brembo's(cross-drilled) from the 430, that l thought would look good of the 55....
'05 ML350SE
Brembo on-line lists two sizes for the 55 and 430, both with the same part numbers. One size is 331 mm OD, 14 mm thick and the other is 345 mm OD, 32 mm thick. Don't know if these are the cross drilled version or not.
