1 - 11 of 11 Posts
I need to change the front brake pads and rotors on the wife's 2008 ml350. I went to oreallys and they said there are 2 different size rotors. 330mm or 350mm.
The vin number on the ml350 is
4JGBB86E48A364511
Thanks for the help ahead of time.
Sent from my SM-N950U using Tapatalk
That suggests 19 inch wheels.
Autohausaz shows 330mm for vehicles without 18 in factory code U29.
That's the same size I used on my '08 ML320.
Be sure to buy two rotor set screws. One side unscrewed, but the other needed to be drilled. They are generally a one use item as are the bolts holding the caliper bracket.
In my case the right rear pads wore out first.
trying to find out if I need 330 or 350MM rotors 2008 ml 350 Vin 4jgbb86e88A418893. 19inch wheels believe it should be 350MM but want to be sure.
thanks
For your VIN, EPC lists the part as A1644211312. That's the 330mm rotor.
1 - 11 of 11 Posts
