1986 560SL 1986 420 SEL
My 1986 420 SEL vibrates when braking. Seems to come from the left front wheel. Tonight I removed the wheel. Turning the hub by hand it turns easily for about 220 degrees. The other 140 degrees is hard to turn. I do not have a dial gauge. My guess is I have a warped rotor. Before I start doing surgery I'm asking if you agree that the partial hard rotating is in fact an indicator of a bad rotor. Or is it something else.
Thanks much
SuperModerator
1986/1990 W126
Probably. You could take out the pads and see, but it's likely. MB dealer is often the cheapest for brake parts, oddly.
I replaced the rotors and pads. Car stops! Wheels have not fallen off!
Shutter is gone. Brakes smoothly. Most time consuming part of this job was to find a 10mm hex socket to use with my torque wrench. Went to four stores without finding one. Finally borrowed one.
