After reading Bazzle's post regarding to the fix of the roof problem, I bought the switch from the dealer and able to found the location of the switch. Thanks Bazzle.
http://www.benzworld.org/forums/r170-slk-class/1292734-roof-switch-repair-rear.html
I wasn't able to take out the switch. Do I have to remove the panel in order to take out the old switch? To me, the black plastic panel is kind of huge to remove.
Bazzle said:
I took it out thru the removable cover above the CD stacker.
I put my hand thru the brush to hold.
Bazzle
Thanks for the reply Bazzle. It seems like my problem is different so that wasn't the switch I need to change. Well I replace the old one anyways just in case.
My trunk opens and windows go down but the roof won't fold and go down to the trunk. All I hear is motor noise at the back.
If anyone could help on which switch should it be to change, it will be much appreciate.
Wow. Thanks eKeith. This is very useful.
I think what I need is the S69/11 switch. I am going to order it and see if it works.
Thanks guys.
2002 SLK200 K
Thanks guys.
You're welcome :thumbsup:.
I just used this info to troubleshoot my roof problem. I replaced s69/1 and now it works fine.
