Hey guys,
I'd really appreciate some help here: I've done every type of search possible and have found tidbids of related info., but nothing that seems to truely address how I might cure my problem. I recently purchased an '03 SL55 and its got a well cared for history with 45K miles on it. There is an occassional rattle and/or creek that "seems" to be coming from the roof. I've tried to isolate it, but as soon as I think I have it, it moves elsewhere! Seems like pressure on the headliner in various areas does have an impact but the noise is almost certainly from the mechanism behind it which I'd describe best as a "creek". Anyway...research on this forum and others suggests this is a common problem and that rubber seal treatment (such as gummi phfledge or something similar) can have a huge impact. Also, some say its a common problem that is simply inherent in the vehicle and can't be cured (to which I say BS). Others say there are various points of contact and or adjustments that can be made...but no where can I find a step by step diagnostic addressing this issue. Can anyone help? I can't figure out where the adjustment points must be on this roof that might allow me to try and solve the problem. I've tried cleaning the points of contact and treating the rubber seals (which did have a postive impact), but did not resolve all. It seems to me there must be some simple way of adjusting the "tightness" with which the roof clamps secure themselves, no? Anyone have a step by step instruction or insight to help? Thanks much in advance!
