M
Guest
Anyone experience a rattling directly above the second row seats. It's about 12 inches back from where the sunroof appears to retract into. If I take my fingers and push gently in quickly, I could hear something like a loose cable. Any help appreciated. mark
S
Guest
Discussion Starter #2
Believe that a couple of cables run thru that area and there is a drain tube for the sun roof lip channel that runs thru the area. Have heard of a broken or missing clamp for the drain tube causing a rattle.
T
Guest
Had the same problem in my 2001. They said it was insulation. It was fixed (also in doors) and have not had a problem since. (10000 more miles)
D
Guest
Try...
going to the CD changer access panel in the cargo area. Open it, and reach up into the C-pillar area. You will feel a couple of wires, IIRC. If you shift them around, it may help.
