1 - 10 of 10 Posts
Anyone know where I can find a rubber/plastic plug for the antenna hole? My Teleaid antenna got busted off and I would rater plug the hole than replace a worthless antenna. Duct tape is working now but isn't a long term solution :)
04 Adventurewagen
This antenna also connects to the OEM phone system.......if you have one installed.
96 G300DT
Hole plug
Measure the diameter of the hole and hit up a regular hardware store. Most will carry an assortment of nylon plugs. Then glue the plug into place
Tried the big box stores without much luck before I posted here. Maybe I will try an Ace hardware.
04G55AMG,08R320CDI
If you search for "antenna plug" on ebay, lots and lots of different ones in different sizes.
1999 G500, 1997 G300, 1986 300GD, 1983 280GE
I went down to ACE and picked up a black nylon round patio chair glide. It projects approx 3mm above the hole, fits it perfect and sealed with a elastomeric black butyl rubber sealant.
My new G500 has no hole up there, all the better.
2005 G500
Mine got ripped off in a parking deck. Temp fix was a 5/8 rubber plug from home depot. just stuck it in there, ran it through a car wash, no leaks.
2003 G500 - Tectite Grey Metallic
Sjarvis, It may be a temporary fix, but we definitely care for our 'G' babies and I would recommend applying GE silicone II. It comes in clear, white, almond and black colors. I prefer clear application. This type of silicone is rated for internal/external application and is rated to last 30 years! No worries about sand, water or dust getting anywhere. :D
1 - 10 of 10 Posts
