As many may have noticed, I joined the "blinking light, cluster light on" club for my roll bar a few weeks ago when the battery went south. I was very careful to recharge the battery with a trickle charger, but still had errors that needed to be cleared. DAS HHT cleared them, everything worked fine for a few roll bar up and downs, till a plastic piece popped a hydraulic line loose.
Cleaning up 1 liter of hydraulic fluid under the Bose amp and rear carpet is another story.
After this the roll bar controller had code 136 for the controller that couldn't be erased, just like a few other had experienced. and the light issue.
I found another controller to borrow and try but it had Code 134 for the roll bar and same symptoms. then I found another one to try, scanned to make sure there were NO stored codes. There weren't any. Installed it and SUCCESS.
No lights, no roll bar up after top cycling, everything works as it should and after cycling no codes showed up.
So..... it does appear that codes 132-138 mess up the roll bar section of the controller. I guess the next step is to see if BBA can really fix this error.
It would be nice to see what the codes correspond to.
And I suspect (But have no proof) that ebay controllers are going to be a crap shoot. First, many are from cars involved in an accident. Second, not many folks checking them use DAS to check codes, they probably just verify the top cycles, and don't either know to check for roll bar code symptoms or may not even know the flashing light and dash light are an issue. If they even notice it. cycle the top with the ignition on and not running and everything looks ok. everything goes up and down, roll bar comes up, not flashing light, and dash lights are all on anyway.. This ones good put it on ebay.
