1 - 20 of 24 Posts
1984 U1200AG (soon a hydrostat and rotzler teibmatic winch)
I was wondering if these were standard for something other than Unimogs. Can the plastic inserts be purchased separately?
Anyone already been down this road?
As you can see from the photo mine has departed somewhere in the snow up here. That is the shifter for the crawler gears, clearly some zip ties will make an "ok" temporary fix so I am not in a rush.
Automotive tire Motor vehicle Bicycle part Rim Wood
U1000Ag
When one of mine gave up the ghost, I contacted AV and they ordered new parts for me. However, the replacement parts were different - genuine MB parts - the plastic insert types no longer being available. Not to say you may not be able to get some NOS parts anywhere.
The new parts require some modification to the existing bits - the ball ends having to be removed and coupling nuts/bushes to be made or purchased separately.
Some more info here: SBU reverse lever linkage
Gas Auto part Font Machine Nut
Gas Nickel Cylinder Auto part Metal
1988 U1300L RW1 Working gears Dual Tanks AC Rigged for Camping Plus: 91 F250 HD 4x4
Did not see anything on Belmetric site, but McMaster-Carr has a pretty large assortment of ball ends, assemblies and rods. Might be easiest to just make what is needed.
One possibility from that link:
Don’t know if the ball stud is threaded, or a peened over interference fit, but one could always drill and tap for a slightly larger thread size for the ball stud.
All FWIW
Lee
U1450L DOKA
I pulled some parts out.
  • The threads on the Rods are M8 -1.25
  • The sockets are Right Hand and Left Hand threads on opposite ends of the rods.
  • The jam nut on the Rod takes a 13mm Wrench
-The flats on the socket ends take a 12mm Wrench
-The ball is ~ 12.90mm diameter
- The ball fixture is pressed into the shift lever arm.
-The diameter of the shaft on the ball fixture is ~ 10mm .
Material property Household hardware Fashion accessory Metal Electric blue
Audio equipment Electric blue Close-up Fashion accessory Headphones
Audio equipment Jewellery Auto part Cable Electronic device
Kitchen utensil Tableware Metal Cutlery Fashion accessory
Hand tool Wood Bicycle part Tool Auto part
Metal Fashion accessory Musical instrument
Hand tool Pliers Metalworking hand tool Tool Yellow
1970 411.119 Mystery Mog, 1979 L-1116 Flatbed, 1975 L-1113 Box
The plastic inserts might be available from 80s diesel mercedes cars. Some research would be needed to determine which car had that size hardware.
I had a 83 300SD that needed an insert for the throttle linkage with similar ball ends like that and germanautoparts.com had inserts in stock.
U1450L DOKA
I’ll be interested to see what MEREX sends to you.
One of mine shows cracks in the plastic…a prelude to failure.
One of the socket bodies is not round - it looks like a hammer blow, rather than abrasion.
One of the shafts is arrow straight, one has slight doglegs in it and a few wear marks, where it was rubbing against something.
It is straight enough.
The plastic inserts look like they overlap the metal body on both the open and closed sides. It may be that they were heated and soft when installed in the housing. This might explain why the inserts are not available by themselves.
Assuming that is true, or whether that is a provisional UNIMOG truth. They might have been available in the past, or never.
Wood Gas Metal Circle Auto part
Wood Yellow Amber Gold Tints and shades
Gold Wood Amber Rectangle Tints and shades
Light Green Handwriting Gas Circle
Wood Kitchen utensil Metal Audio equipment Auto part
Food Ingredient Custard tart Recipe Wood
U1450L DOKA
If the female threads are M8 - 1.25, it might be worth it to buy one to compare it. However, I didn't see any specifications, on either the Ebay listings nor on Amazon. There is no mention of right and left hand threads, which are necessary for the UNIMOG linkages.
They look close, but they might not share much besides the looks.
U1450L DOKA
I'm liking what I see on the McMaster-Carr link.
The ones with the Neoprene seals don't have a Load cap. rating, and they pivot 35°.
The ones with the Rubber seals have a rating, and pivot to 34°.
I think the thing to do would be to push out or drill out the ball stud from the factory lever arms, drill them out and weld in a regular M8-1.25 nut. Clearance is somewhat tight, so I don't think a coupling nut is a good choice. A jam nut on the threaded male stud, and you should be good. Instead of a jam nut, a thin spring type lock washer and thread locker would be less bulky. Then trim the male stud of excess length as necessary.
I think either one would work, as the rating should be sufficient for a hand operated lever, one that probably isn't used every day. The Neoprene Seal equipped pieces are plated steel, so I think they may be stronger, whether they are rated to not. The Original MB pieces look to be zinc, and they do not look to be built for high strength, so I think the McMaster-Carr ball joint linkages would be an upgrade. Price-wise, the Rubber Seal versions are about twice as much, so maybe they are the way to go, thinking you are paying more to get more ?
One consideration would be clearance - but I think the best way to pin that down is to buy a couple and fiddle around with them. They look like they would fit, but I still have to measure the threaded depth on the OEM pieces, and so on.
Maybe today I can play around with my OEM pieces and try to come up with a number for what their pivot range is.
Automotive tire Motor vehicle Gas Rim Automotive wheel system
Rectangle Font Line Parallel Number
Rectangle Font Music Parallel Slope
Rectangle Font Parallel Pattern Slope
U1450L DOKA
The OEM piece is close :
Shank Thread Lg. = 20mm (McM-C = 14mm)
Shank Center Lg. = 30.3 mm (McM-C = 28.5mm)
The OEM rods have about 25mm of threads on each end for adjustment.
Handwriting Font Art Drawing Writing
U1450L DOKA
So, between the two rod ends, with the McMaster-Carr pieces, you'd lose less than 1/2" in adjustability. The McMaster-Carr piece will bottom out less than 1/4" sooner than the OEM piece. I think that will work fine. With the slightly shorter Shank Center measurement ( 28.5mm to 30.3mm), the McM-C end will want to extend further (screw out) than the OEM piece, so bottoming out should not be an issue.
Electrical wiring Automotive tire Coil Gas Auto part
U1450L DOKA
Just messing around with the pieces, I came up with this range of motion for the MB parts. It may be off a little, but just based on the angle at which interference takes place, I think it is a reasonable guess.
It is essentially the same as the McMaster-Carr pieces.
In use, I think only a fraction of the range will be used, because the shifting action is a fairly short fore and aft throw. In any event, it appears that the McM-C pieces will cope with the alignment requirements as well as the factory pieces.
Time will tell.
Automotive lighting Circuit component Handwriting Wood Pest
Wire Jewellery Cable Terrestrial animal Metal
Automotive lighting Font Jewellery Cable Audio equipment
Automotive tire Carabiner Audio equipment Rock-climbing equipment Cable
Arthropod Insect Grey Triangle Pest
U1450L DOKA
More fiddling, in order to check the previous results.
Matched a grommet to the OD of the ball.
Dummied up a ‘stem’ for the ball.
Inserted the grommet ‘Ball’ into the socket fitting, and
swung the arc.
Results about the same as the previous method.
Audio equipment Font Gas Electronic instrument Circle
Gas Circle Auto part Metal Font
Wood Metal Auto part Household hardware Fashion accessory
Automotive tire Asphalt Line Wood Audio equipment
Bicycle part Automotive tire Metal Wire Jewellery
Bicycle part Handwriting Gas Auto part Nickel
Gas Nickel Automotive exhaust Muffler Auto part
1 - 20 of 24 Posts
