My friend slammed the top down while Manually closing the roof and now it is Stuck in the LOCK position and it's not closed, how do I unlock it so I can shut it properly? 99 SLK230
Please and Thank You!!!!
1998 , SLK 230
Have you looked the instructions for manual roof operation in the MB glovebox manual? If you've lost the manual there's a link to a pdf version in the sticky's at the top of this forum.
From memory there's a key to unlock the roof in the trunk tool kit.
I got the manual operation down, problem is, it won't unlock with the hex bolt on the roof panel, the PIN on the passenger side is sticking out and the roof is ajar, sitting on that pin. The hinges at the back glass and roof are in a locked position as well. Can't put the top down, can't get the pin back in so I can close it and manually lock it. Please Help if you can!!! This is awful!
1998 , SLK 230
I've never seen that happen before . Maybe put a photo up of the protruding pin and someone will figure out a solution.
