2000 vito 108cdi , 2000 ml 270 cdi
Hi my dad has got a 2005 smart roadster but it seems to be over boosting and then going into limp mode we have took the turbo off and cleaned it and checked all the pipes on the waste gate are correct , please can anyone point us in a direction so we can get it fixed thanks callum
SL500, GLC300
there is a smart car roadster?!?! cool! :thumbsup:
2004 S500. 2000 CLK430 Cab, 1999 C43 AMG. 1999 S500. 1999 S320. 1977 230 4 spd, 1972 280SEL 4.5
check the waste gate actuator diaphragm, the lines going to it and the electrical valve.
2005 smart Roadster, 2002 SLK 200K
I also have a smart Roadster and mine is chip-tuned to ~110 hp.
Boost is higher after tuning: 1.5 bar.
Standard is 1.0 bar I think....
How high does your boost go?
If it's higher than 1.5 bar, then there's something wrong with the waste gate.
You have to lube the actuator arm on a regular base.....try if you can still move it.
1993 Mercedes 500SL (r129) , 2001 Mercedes E240 (S210)
If it lights the engine management light and loses all power and it can be reset by pulling fuse 27 for 5 minutes or clearing the ECU errors then its most likely the cycle valve (Boost control valve). Thats the one thats in a metal case (as opposed to the one in a plastic case).
Swap it out and it should be fine. The Roadsters are susceptible to boost control valve failure and will regularly need a new one. A friend of mine carries a spare in the car and has modified its location to be easy to change he's had so many fail
