I have the stock steel wheels with the short wheel bolts. I would like to put the after market alloys on. Where is the best place ( Toront GTA)
to get the proper size bolts other than the stealership? One tire shop said they usualy put studs in with thread lock and use a nut instead of the supplied bolt. Anyone doing this, I see the hub has a through hole so you have to be carefull not to go to long.
