1981 300CD
Does anyone know what are the biggest size in rims with low pro tires that you can fit on an 81 300CD?
2006 E500, 2013 S550 and a retired 88 SDL
Check out Tire Rack
TireRack.Com is a great site that will give you the info you need for changing out wheels and rubber within the spec of your car.
If you want something thats a little more outrageous you'll have to dig a little deeper.
I went with Eurotech Rims and Sumitomo-245/40/18's on my 1987 300SDL I don't think going bigger is going to work because ride quality is lower with the low profiles on such a heavy car.
I'm switching back to the stock rims on winter rubber at the first snowfall.
In your case you want to be careful about putting a wide tire on because of extra stress on the powersteering system.
Good luck with your search.
