Hello, New to the board.<br>
<br>
I just purchaced a 1989 300CE with the stock rims which I beleive are 15x6. As you can imagine, I desperately need a 'Wheel Update'.<br>
<br>
Where can I find the exact stock size of the wheels including the bolt pattern? / What other stock wheels will fit this car? I'd like to stay with Factory looking 15inch or 16inch if possible or possibly a 5 or six spoke design.<br>
<br>
Comments, suggestions, and pics welcome<br>
<br>
Discussion Starter #2
The stock wheel size on a 300CE is:<br> 6 1/2Jx15H2<br> 5X112mm(spread)<br> offset: 15 hole rim (et48)<br> <br> 6 1/2 inches = width<br> diameter =15'<br> et48= disc depth<br> <br> A nice upgrade would be a set of 8 hole wheels from a 1995 E320<br> Another option is a set of 8 hole wheels from a 1995 E420(16')<br> <br> Also try tirerack.com and you can see a array of tires/wheels that will fit your car very nicely as a upgrade.<br> Hope that this helps<br> Phillip
