88 560SL - 01 C240 - 02 W210 4matic Wagon - W212 4matic wagon
Does anyone know if the bolt pattern from a 560SL (W107) is the same as the bolt pattern on a W210?
Dug the 560SL out of the garage and surprisingly the thing fired right up after sitting for basically two years.
I replaced the rims on the SL 6+ years ago going up to 16" rims with 225 55 16. I was thinking that maybe I could put the rims on the wagon with new tires and order a new balanced set of rims/ tires for the SL.
The original rims on the wagon are tired.
I will have to look to see if the offset for the replacement wheels is on the paperwork -- I believe the wagon is 35mm
2005 W215 CL500
The pattern is the same.
But you must check the offset, and if that fits, then you must check the bolt size required.
Tire code looks to be late 2002 -- so it was a bit more than 6+. They sent me new lug bolts with the replacement rims - so that should work.
My SL was delivered with chromed rims -- was a popular option on the red and black SL's in the 80's - they eventually corrode at the tire bead line and leaks develop- not worth fixing.
