Hi,
I'm new in this forum, My problem is that if I pull up or down the turn lights' lever, in each case the right bulbs start to blink.
If I push the 4 way flashers button,each bulb work fine.
I've changed the lever but I've not solved the problem.
I remember the problem started after I pushed the 4 way flashers button.
Is possible the problem could be the 4 way flashers button?
Thanks,
Mau
Discussion Starter #2
it seems I solved the problem.
With the key in position 2 and the direction lever pulled down as for left direction and the right turn signal blinking, I've unplugged the fuses:
nr.12 (30 amp) Cigar lighter. Trunk plug socket. Radio. Glove compartment light. CD changer.
nr.13 (30 amp) Power window front 2 x
nr.14 (15 amp) Instrument cluster, Timer, Wiper/Washer pump relay. Switch group COC (Mobile phone)
nr.15 (10amp) Air bag control module. Sensor. Automatic Child seat recognition.
At nr.15 fuse unplugging, the right turn signal stopped to blink,
and the correct direction (left) started to blink.
I've plugged the four fuses and now work fine.
I've tried this trick because the cigar lighter has always given some problem when I plug my mobile charger.
I hope the air bag control module will work correctly after this trick.
What do you think about it, why this trick worked?
May be this trick could be usable by someone else.
Thanks for your attention,
Mau
