1 - 15 of 15 Posts
280 sl '84 5 speed stick
My sl right side rear tail lights are out.
The turn signal works and am not sure about break lights.
What is the fix for this. Is there a particular bulb size and where to get
it. May this be a fuse issue as Ive had some fuse problems last year.
I understand this is a lame q but im a white collar thru and thru except
for doing oil changes and car washes.
many thanks:)
Steve C - '84 280sl 5 speed stick - 192k
1984 380SL, 1973 450SLC
Nobby might even stopp by and change them for you if he can take it for a ride... Where are you located....:)
San Rafael, Ca.:) 20 miles away from AT&T park -
Go Giants!!!!!!!!!!!!
Steve
1986 560 SL
You need to check the fuses and/or bulb .... or pay someone to do it.
The fuse box is under the panel next to the passenger's right foot.
Access to the bulbs is inside the trunk by unscrewing and removing the light assembly. A burned bulb and its proper replacement type will be evident on inspection.
Discussion Starter · #5 ·
Group
Ez fix this time. Examined fuses and all looked ok via visual.
Then removed the right real housing and carefully pulled out the light assembly and the tiny 12v bulb was brown. Went to electronic store for a
test and bought a replacement for $ 3. Installed, tested and put housing and light assembly back and completed work . - All is well.:D
Steve - '84 280sl 5 speed stick 193k
1975 450SL
These days, getting a little 'blue' (or dirt) on the white collar can be considered a bonus. Proof that you are willing to try to save a few bucks by DIY. It adds value to you by broadening your skill set. :rolleyes:
Maybe I'm just cheap, but I'd rather pay $3.00 for a bulb and fix it myself rather than spend a LOT more than that at a dealership.
Besides, it's sort of fun to detect, diagnose, isolate, and repair a problem yourself. :D
Keep up the good work,
Scott
Discussion Starter · #9 ·
This was the EZ fix to the roadster.
The tougher one to solve is that the back-up lights work about
10% of the time.
My indy says its a tough fix and there is the need for a replacement wire harness that is expensive, a pain to install and hard to come by.:confused:
The only other solution suggested was to install a manual back-up light switch. I would need to take memory medication to cooridinate this for sure.
Any thoughts appreciated.
Steve '84 280sl 5 speed stick
R/C107 Moderator
Did he check the back up light switch? It is less than $20.00.
Discussion Starter · #11 ·
Rowdie
As the the break light switch I never asked ( what do I know).:confused:
The indy is a Mercedes only repair store and I have to believe he did.
Is this a diy fix??
Many thanks
Steve
R/C107 Moderator
Fill in your profile with car and location. Helps to not have to keep going back to look.
I don't know about replacing the back up light switch on a manual trans. Here is a parts pic from the EPC. I circled the switch.
Discussion Starter · #14 ·
Dave
Thanks for the pic and location.
I will show this to the indy the next time I go over there.
Where did you find this information??
Steve
The pdf attachment was rowdie's doing. He got it from the MB-USA Electronic Parts Catalog.
There's a link in the 'Info' section of the EGv107.
As rowdie mentioned if you go to the User CP you can fill out your profile and let us know where you're at and such...
1 - 15 of 15 Posts
