1 - 10 of 10 Posts
Hello, I am running 700 miles now with my C300 sports.
I am still breaking in the engine. Since two days ago, I have noticed a change with my ride. It doesn't drive smooth as before and feel like it bounces a lot. I am planning to take the car to dealership tomorrow morning. Does anyone know what might be the problem?
-Tommy from Texas
The S / C button on your gearshift... maybe you changed it to C without knowing?
I think it's for the suspension settings... C for Comfort, S for Sport
2006 C280
Sorry, that has nothing to do with the suspension!
S allows the transmission to use all 7 gears, and holds upshifts a bit longer.
C starts the trans in second gear, and causes earlier upshifts.
American cars don't get any suspension adjustments, at least in the current cars.
Check your tire pressures, for starters.
2013 C250
Correct, C and S is for tranny only.
2008 C300 4Matic
Is this the same for canadian cars? can anyone confirm that it will not do anything to the susupension?
2013 C250
There might be some info in the owners manual regarding the use of the S/C settings and what they do.
I experienced the same ... it was kind of like the parking brake was on sometimes while accelerating ...
1500 km later... now it runs as smooth as butter.. on C or S.
2006 C280
Firstly, the complaint was about ride quality - can't imagine what the transmission has to do with a choppy ride.
Second, the query came from Texas.
USA cars get no suspension adjustments in the '08 model year. A sudden change in ride quality almost always can be traced to tires and / or tire pressures.
Has there been a spike in air temps since you bought the car? - tire pressures go up or down about 1 psi for every 10 degree F change in ambient temps.
Thank you so much for so many response. Here in Texas, temperature is hitting 100F now that it is just starting to get hot. I have the AMG 18" wheels and all my wheels had close to 35-40PSI when I checked yesterday.
1 - 10 of 10 Posts
