Comparison
<p>So you're saying the sequentronic is no better than the standard auto?<p>No, I am just trying to explain the difference between the Sequentronic MANUAL-based 6 speed gearbox (without a power-sapping torque converter) and the AUTOMATIC 5 speed gearbox (with a power-sapping torque converter) that is fitted to the C 320 and C 32.<p>Because the Sequentronic is in effect a manual gearbox, the acceleration and fuel economy should be better than an equivalent car with the 5 speed automatic. In fact, in performance, a Sequentronic car should be faster than a regular 6 speed manual, as its computer-controlled clutch and shifts are way faster than a human driver could do (according to M-B).<p>I've no idea whether Sequentronic is a more pleasant gearbox to use, or how smooth or rough it may be if you let the Sequentronic ECU do all the gear shifting for you ("automatic" mode). It seems to me that in "automatic" mode (where the driver does not touch the sequential shift lever), the 6 speed Sequentronic gearshifts should be more coarse and unrefined than the 5 speed automatic, as there's no torque converter to soften the shifts. The Sequentronic may also shift more coarsely tha a well-driven manual gearbox. I don't know, I live in Canada and I've not been able to test drive a Sequentronic car yet.<p>I am not judging one gearbox over the others, simply trying to point out the differences between them.
