Moderator
M20
had a bulb out error and pointed to the front RH parking light bulb. checked the bulb and it works. Replaced the bulb anyway still didnt work. Checked the connectors with a voltmeter and its only giving out 4V. Any reason why this is?
may be relevant info:
99 SL500
just replaced the headlight switch with a brand new genuine unit a month ago
1993 Sl 500
It may be an earth fault. See if you have voltage on the earth connector, if you do try running a temporary earth and see if you get 12 volts at the feed.
dark blue 1992 500 sl
i had same problem tried all finaly fixed by changing lighting relay not new as no longer available
remove 6 screws from fuse board relay below see pelican parts web site for directions
nb 1992 500sl rhd
