hello all,could anyone tell me what cause,s the revs. on my s 280 to hunt,i.e go from normal idle to almost cut out and then up to 1000revs. this only happens at normal running temp. 1999 s 280 90k
Moderator
My S320 would jump 300 RPM, and I cleaned my mass-airflow sensor with VCR chamois flat swabs and electronic contact cleaner(with no lubricant)-Mass-Airflow sensor is very fragile, and it can be defective. This solved my problem. You may have a very soiled air filter, or very dirty throttle body. Others here on the forum may have other solutions.
Hope this helps.
Martin
