Does anyone know which is the reverselight power wire at the harness by the trunk lid hinge? I'm trying to tap into it for a reverse sensor without prying the liner open at the bulb socket.<br> <br> Thanks!<br> Ray<br> <br>
Discussion Starter #2
Wire is a white yellow above the right rear wheel well. Good luck as I have just done one and the vss signal intermittently triggers when sitting still causing the alpne nav unit to think you are moving and keeping you from changing destination.
