I own a mercedes benz C200 1996 model, milage is around 115000km and sounds good when driving it. However a month ago after i had decided to sell it, the reverse gear began to slip. Later on i noticed that this happens only when the engine has reached its optimum temperature. Also when it was last serviced i noticed that the mechanic used some ATF manufactured in South Africa. All the forward gears appear to be functioning well, only the reverse gear seems to be the culprit. I kindly request someone in the network to give some advice so that i can be able to diagonise the problem. My challenge is that here in Zimbabwe there are no experts in Automatic transmission, everyone that i have consulted so far says i should get a new gear box. HELP PLEASE
