continued...
It's easy to install new switches once the drier is out of the vehicle and on a bench:
Handy sheet that came with the reseal kit from centuryautoair.com. According to Bob, those two O rings will be left over from this project. One of those O ring comes with the shaft seal kit (bought separately) and the second one is not applicable to this compressor.
Cans of R12 goodness and sealant can:
Well, that's about it. I hope this post inspires confidence in you to rebuild your a/c compressor. About the only specialized tool that I can think of is a hydraulic press for pressing out the clutch bearing. I think you can do the same thing using a decent size vise. Incidentally, my bearing was super smooth and spun freely for a long time but while I was in there, figured it was time.
This project is about cleanliness so think like a surgeon! The case needs to be cleaned so crap doesn't fall inside once you have it apart. Clean and clean often :thumbsup:
It may not be a bad idea to have on hand an extra allen bolt that I destroyed in the process of removing the comp. If not, you should be able to source it from your local hardware supplier. Be sure to apply a little bit of anti seize on the thread before re-installing. This is a steel bolt living inside an ALUM housing for 20+ years. Probably would be a good idea to squirt a penetrating fluid on this bolt for about a week just in case it's stuck in there.
Time to rebuild compressor: 45 min
Remove compressor: should take about half hour unless you have a frozen bolt and in that case, two hours!!
Install compressor: an hour with minor aggravation.
Let me know if you have any questions.
Cheers.
Cheers.
