I am looking at acquiring a 1979 450 SLC with 121K miles that has been sitting under a carport for about 2 years. It was simply parked after last being driven without being prepared for storage. The car is in Georgia. Any input on what I can expect will need replacing/repairing OR on what a Mercedes may have withstood during this time that would normally have had to be replaced/repaired? The interior does have some mold. Any specific products that will get rid of the smell?
W211/W210 Estate /W209/W208
You Will Start with Tune Up, Oil Change, Fuel filter change,Brake fluid Flush,New Batter...
You Will Start with Tune Up, Oil Change, Fuel filter change,Drain and Clean the Gas Tank,Brake fluid Flush,New Battery,Belts maybe Hoses,Renew the Coolant, only a Start...Inspect for Rodent Damage!
Then a Strong Detail
Try www.Mercedesshop for some advice...lots of Info there!
Good Luck!
