Restoring my 86 190e 8v 5 speed
Finally getting into the restoration of my 86 190e 5 speed. I bought the car for $1000 with a wrecked passenger side door and fender and a lot of aftermarket parts. I scored a new door and fender at the local pull a part for $50 and a complete perfect dash for $50 as well, the dash was a lucky find. The car came equipped with h&r springs and sway bars, adjustable strut tower bars, Bilstein Sport shocks, Bosch Euro headlights and hella smoked taillights. I know it's an 8valve but I've grown pretty attached to it much like my 89 300e and I figure if I put $2000 in it with me doing all the work I'll still only have $3000 in it. Since I'm an automotive painter I'm going to replace the rocker panels which have rust at the jack points and respray the whole car after all the suspension and underhood work is done. Here's the list of new parts I already have
Plugs
wires
cap and rotor
New injectors and seals
valve cover gasket
oil pan gasket
serpentine belt
belt tensioner
belt tensioner shock
timing chain and guides
Motor mounts
tranny mount
All new radiator hoses
thermostat
overflow tank
washer fluid tank
ac compressor
ac condenser
ac drier
hood pad
strut mounts
ball joints
center link
tie rods
steering dampener shock
wheel bearings and seals front and rear
control arm bushings front and rear
400e brakes front and rear
cross drilled slotted rotors
stainless braided brake hoses
new parking brake shoes and cable
new sachs clutch kit
rear suspension link kit
adjustable rear camber arms
flex discs
new magnaflow exhaust with hi flow cat
new steel rocker panels
This is what I've got so far and I plan to have all the engine and suspension stuff done in about a month just because I'm sending parts out to the powder coater as I get them off, such as control arms, sway bars, springs and wheels. Then I plan to tackle the paint and body to be done by spring so I can just hopefully drive it this summer and work on the 300. I'll post pics of my progress as I go along.
Plugs
wires
cap and rotor
valve cover gasket
oil pan gasket
serpentine belt
belt tensioner
Motor mounts
tranny mount
thermostat
overflow tank
washer fluid tank
ac compressor
ac condenser
ac drier
hood pad
strut mounts
ball joints
center link
tie rods
flex discs
