I FIGURED IT OUT!!!!
Well the manual has directions to reset it, but if you follow those directions it doesn't work. So here it is...pretty much the same thing but with a slight modifications.
1. Turn key to position 2. (That's the furthest you can go without starting the car)
2. Press 0 button twice and then press third time and hold.
3. While still holding 0 button, return key to position 0 and then back to position 2.
4. Keep holding 0 button in position 2 for about 10 seconds and 10000 miles should show up!!!
By the way, I have a 98' CLK 320
[8D]
