2x 1986 190E 2.3 16V Cosworth, 1975 450SE, 1995 E320 Convertible
is it possible to erase all the dtcs or any codes on ecu or any other main computer on w215s without scanner?
can you able to see the codes or erase them through command screen??
any ideas?
SL500, CL55, E350, E320
OBD-II scanners are cheap nowaday. You can try to disconnect the battery for 30 minutes and plug it back. Make sure you have the radio code tho.
