Can anyone out there tell me of a way to reset the service B warning that I have gone passed my service interval? I don't know if it needs a plug in, or if it can be done by turning the ignition and pressing and holding of buttons technique? Can someone out there answer this? The car is a 2002 240E before the face lift model.
Many thanks from a home mechanic thats good with engines but sadly lacking in the IT department!
lol Steve(uk)
Thanks,advice greatfully recieved-service reset done!
Hi there, I just contacted prev owner he is sending me a manual! I have done what you say and it is reset, that is great! As DIY mechanic I am doing all my own servicing, but what does service A and B entail. I have just changed engine oil replaced oil filter, air filter, autotransmission oil, new brake pads front and replaced brake fluid, drained coolant and replaced with fresh anti oxidant antifreeze, I have replaced the plugs(HT leads were ok). So basically I have gone overboard with the service. So I should have covered everything. Is there anything I have missed? as I am new to these engines only having owned the car 6month. Thanks for any advice offered, and once again, many thanks for the advice already given.
lol Steve (uk)
2002 CLK430
Here's the service schedule according to my MB service booklet (the one that MB USA supplied with the car).
A-Service — First visit at approximately 10,000 miles or 1 year, but determined by Flexible Service System; then every 20,000 miles or 2 years.
Services performed:
Interior
1. · Function check
2. · Check warning and indicator lamps, illumination and interior lighting
3. · Check windshield wiper, windshield washer system, headlamp cleaning system
4. · Reset maintenance service counter in instrument cluster
Wheels, brakes
1. · Check front brake pads for lining thickness
2. · Check tires for damage, condition
3. · Correct tire inflation pressure
Engine compartment
1. · Change engine oil and filter
2. · Fluid level checks of the following:
1. · Engine cooling system, antifreeze and corrosion protection
2. · Windshield washer system
3. · Brake system
3. · Check and correct battery fluid level
4. · Check battery condition
5. · Check catch, safety catch and hinges on engine hood for proper operation
Trunk
1. · Correct tire inflation pressure in spare tire
2. · Check battery condition
B-Service — First visit at approximately 20,000 miles or one year after previous service, but determined by Flexible Service System; then every 20,000 miles or 2 years.
Services performed:
Interior
1. · Function check
5. · Replace dust filter (not applicable to SL-Class)
6. · Replace combination filter (SL-Class)
7. · Check parking brake (function test only)
Wheels, brakes
1. · Check condition/thickness of front and rear brake discs
2. · Check front and rear brake pads for lining thickness
3. · Check tires for damage and condition
4. · Measure tread depth, record in mm
5. · Correct tire inflation pressure
Underside of Vehicle
1. · Check for major components leakage
2. · Check for chafe marks, line routing, damaged components
3. · Check condition of front axle ball joints and rubber boots
4. · Check condition of mechanical steering components and rubber boots
Engine Compartment
3. · Check and replenish all fluid levels
4. · Change engine oil and filter
5. · Check engine cooling system, antifreeze and corrosion protection
6. · Check brake system
7. · Check power steering
8. · Check Active Body Control
9. · Check windshield washer system
10. · Check and correct battery fluid level
11. · Check battery condition
12. · Check catch, safety catch and hinges on engine hood for proper operation
13. · Check condition of poly V-belt
Trunk
2. · Correct tire inflation pressure in spare tire
