Can you say Loooong extension??? You can get at the bolt with an extention that puts you a...
Can you say Loooong extension??? You can get at the bolt with an extention that puts you about as far back as the transmission with the ratchet handle. The bolt is nothing more than a socket cap screw and so all you need the proper 10mm allen key type socket to get it out. Take your time, look at everything and you should be able to figure it out.
As for the mechanics who could not do it, well.... I won't repeat what was said earlier.
