Im new here to benzworld and needed to know how to replace the driver and passenger side windows on a 91 mercedes 300e. Any help would be greatly appreciated.
Do a search on this forum, it's been done quite a few times.
In a nutshell, remove the door card (interior panel), remove the splash liner (partially), remove the window regulator, remove the rubber strip that sits at the bottom of the window (with window up), remove window.
You will have to angle the window to get it out. Be patient, it will come out. It helps a great deal to have a couple of small window suction tools, unless you have a helper.
