2008 ML350 Iridium/Ash
Not many choices out there in this size. With concerns about speedo inaccuracy and/or tire rub, has anyone relplaced with a different size?
(searched this forum '265/45-20). Thanks, Brian
'09 ML550, '12 BMW 650i Cab (lucky wife)
It's easy enough to calculate the tire's diameter, so your speedo's accuracy will be affected by exactly the same percent as the difference in diameter between stock and aftermarket tires.
I don't know specifically about the ML, but my experience with other vehicles is that rubbing inside the wheelwell is more a function of the wheel's offset than of the tires, unless you go hugely oversize.
