how would i go about doing that ? :confused:i unscrewed the screws above the license plates where the little lip type thing is where they lights are located but it wouldnt budge. i didnt want to break anything . can any one help me ? thanks in advance:thumbsup:
D
Guest
sometimes you have to use a small flathead. If you look at the housings you will see on the sides there is a little slot for you to stick a small flathead screwdriver and pry downward gently, they are sometimes held in there with a sort of leafspring type clip.
P.S. if you are replacing might as well upgrade to the LED lights, they use less energy and last pretty much the life of the car so you'll never have to replace them again. If you need a link let me know.
Open your boot, remove the small clips around the inner boot cover. Remove cover. You will see the bulbs there.
Initially I thought that the way to replace these was the way you are trying. But, the trunk garnish you are trying to remove is riveted in place I believe. :)
