replacing engine mounts ok to jack up on oil pan
6.7K views 17 replies 9 participants last post by  Benz 1
#1 · (Edited)
replacing the front engine mounts on the sec can i put a piece of wood under the oil pan and lift engine or will this damage the oil pan
are the engine mounts both the same for both sides or are they different
#17 ·
I replaced my mounts on my E320 by putting the car on jack stands. Then I used a piece of carpet wrapped around a 4x4 and jacked it by the oil pan ONLY HIGH ENOUGH to remove the mounts. I’m not sure if your mounts are going to be the same or not. Mine appeared to be the same and I bought them from autohaus az. Hope this helps.
#7 ·
Agreed you can safely lift the motor by the oil pan as long as you use a sturdy piece of wood large enough to spread the load. I used a 2 inch thick roughly 8 x 8 inch block of wood on my 6.9 with no issues. Make sure you disconnect the fan shroud and the throttle linkage at the firewall to avoid damage.
#12 ·
Wood works for jacking on the pan just make sure it is long enough to go across the whole pan so the lifting force is applied close to the pan bolts.
Also make sure you pick out all the gunk out of the hex heads before putting in the allen wrench or socket . The little shocks can be reused if they still dampen , the rubber is usually junk though and should be replaced.
These motor mounts are to soft in my opinion and collapse to quickly. Some fill the mounts with silicone to make them more robust.
#14 ·
I would not use any kind of Loctite on these bolts, assuming you mean the 2x smaller hex bolts holding the mount to the frame as well as the large one bolting the mount to the engine. Anti seize a good idea as these can be a prick of a time to get loose, so at least next time it will be easier. Remember to torque to spec, at least the large main bolt from memory I think is 75nm.
#15 · (Edited)
thanks i just used ant seize grease, the small allen head bolts a tightened as much as i could i will retorqure the main bolt tomorrow again as did not have torque value with me just tightened it well
the engine mounts fell out in two pieces
any idea how to tell if the engine mount shocks are any good,when removed they had resistance each way but did not push back out when pushed all the way in or if they did they were very slow in movement
#16 ·
Not a good idea to jack up the motor on the oil pan even on a steel oil pan unless you really know what you are doing. You definitely CANNOT do that with an '86-87 300 diesel 126 because that has an aluminum oil pan and they will crack.
#18 ·
for anyone doing this jiob i can confirm the mounts were both the same part number if the part numbers do vary at mercedes then there must be a material difference but physically the units are the same
the advice the remove the throttle cable bar was a must or else it would have bent whilst lifting up the engine
