I have diagnosed 'rough engine' as being a problem with one of the coils on one of my cylinders (0300, 0302 - engine misfiring on cyclinder #2). Question: how hard is it to replace a coil - is this something that could be done at home or highly specialized? Thank you.
ReBell
C9H9N Offensive Odor Exuder
2002 ML320, 2005 S430 4MATIC RIP, 2010 F150 Crew Cab
ReBell
How do you know it's a coil? It could be a wire or a bad plug(s).
Add new plugs and wires installed 16k ago....
and then there are the printouts. Have you ever replaced the coils? ReBell
+1
If the OP doesn't mind doing a little diagnostic work, he may want to "move" the problem to another cylinder, if that is possible. The diagnostic error code will confirm it for you. Then the faulty part can be identified with fairly high level of certainty.
Others can chime in as to the level of difficulty for DIY'ers.
99 ML430 - 13 328i
try to switch the coil to a different cylinder and see if the problem goes to that cylinder. if so its the coil, if not has to be the plug or wire to cylinder 2
Discussion Starter · #6 ·
Thanks for the replies...
decided to have my service guy handle the prob. He said the same thing, i.e., he'll witch the coil of cylinder #2 with another & will see if the problem 'moves' with diagnostics.
ReBell
