1 - 10 of 10 Posts
1984 190D 2.2 5 Speed 172k
Hey Folks. I'm about to replace my center vent assembly. Has anyone who has replaced this before have any pointers or warnings? I just want to make sure I do it right the first time! Thanks in advance. G
96 C36, 87 Turbo'd 190E 2.3-16, 86 SC'd 190E 2.3-16, Brabus'd C32
pull the vents out with pliers covered in a cloth, unscrew the screw on the left side, pull the switches out, pull the cluster out a little bit to get room, open the glove box and wiggle it out.
oh if your middle vent open/closed thing works then disconect it with you got the vents out. you just turn the metal part
Right on. Pretty much as I suspected but I wanted to be certain! Thanks much LAMF.
1990 190E 2.6
Watch out because on the passenger side vent their is a screw that you dont see, its at the top edge right under where the vent would be, but look for it an you'll be fine.
1 - 10 of 10 Posts
