1 - 20 of 136 Posts
'74 & '78 450 SEL
A popular thread in this forum called "Performance Upgrades"
http://www.benzworld.org/forums/vintage-mercedes-benz/1278753-performance-upgrades.html
discusses such modifications as turbocharging, supercharging, header and exhaust upgrades, transmission swaps, cool air induction and other power increases. It also explored the idea of replacing the Bosch D or K jetronic with the MegaSquirt EFI controller and several users (myself included) had done the conversion or were in the process of doing so and there seems to be some interest from others in this specific MegaSquirt project.
In the interest of keeping the original thread on topic about the many possible performance upgrades to vintage Mercedes I'm starting this new thread to discuss specifically the MegaSquirt conversion. I will post to the other thread only when my MS project is completed and can comment on its merits as a "performance upgrade" or when I finally get around to fabricating headers and completing other non MS modifications.
MegaSquirt is a stand alone user-programmable control (via laptop) for spark and fuel and can be adapted to any spark controlled engine with the right choice of components. The conversion can be seperated into two phases (fuel and spark) and each phase can be done completely independently of the other while maintaining vehicle driveability. Here's a summary (vastly simplified) of the conversion from the Bosch K-jetronic CIS to MegaSquirt EFI in my 1978 450 SEL:
Phase 1. FUEL
-- Remove the Bosch CIS components consisting of mechanical fuel injectors, fuel distributor, air flow sensor assembly and miscellaneous warmup and enrichment devices; they will no longer be used.
-- Acquire MegaSquirt II v3, relay board, wiring harness bundle, wideband O2 sensor and controller, set of 8 Bosch 19 lb/hr fuel injectors and fuel pressure regulator (used from Ford Mustang), fuel rail from earlier Mercedes EFI, coolant temp sensor, intake air temp sensor and throttle position sensor (all cheap, stock GM parts).
-- Install all of the above (there will need to be some fabricating of brackets and other "adaptive engineering" to accomplish this) and use the MS software with a laptop to load the default fuel maps to get the engine runnning and then drive around to datalog. Software will revise fuel maps to optimise for peak power at or near WOT and for maximum fuel economy at other times.
Phase 2. SPARK
-- Remove distributor, coil and ignition control module; they will no longer be used.
-- Acquire EDIS 8 module plus coils and wires (used from Ford Mustang), 36-1 trigger wheel and sensor and the necessary wiring.
-- Install all of the above (also requiring "adaptive engineering") and use the MS software to load timing tables. Datalog and revise map for optimal performance.
User 'oughtsix' has succesfully done phase 1 of this conversion :bowdown: and I invite him to post a summary here on this thread. He's done a lot of pioneering work for this particualar setup and has extensive and very useful pictures. I've been documenting extensively as well, and as soon as I can set up a place to host, I'll post pictures, too. Others who are now doing or are interested in doing the MegaSquirt conversion should start posting their projects. :thumbsup:
note: MegaSquirt has a large support community and forums for many applications. MegaSquirt EFI :: Index
I have no affiliation or relationship whatsoever with MegaSquirt.
1965 220S, 1999 Volvo V70 (wagon), 2006 Ford Crown Vic Police Interceptor, 72 350SL 4 Speed
Megasquirt may be the way to go for W126 owners as well now that Bosch no longer supplies the throttle position sensor for the CIS-E unit.
· W123 Moderator
78 450 SL, 84 500sec (Euro), 94 E320 Wagon and 85 500 SEL (Real AMG, 5.4, Pentas & Body Kit)
Hi Guys,
Well I was in the junk yard this weekend and worked out how to do the TPS.
Take one MB Throttle Body with the idle control switch and add a small plate. Then add the tps off a mid eithies ford (Crown Vic) and you have a working TPS for the benz. I will fab it this week and report back with pictures ect.
By the way I have finished my Megasquirt and it seems to work fine.
More later
Jon White
1980 450slc
Hello Hbar and Jon, (and anyone else that would like to comment!)
Have you guys had any luck with a TPS solution? I keep looking at the 65mm ford throttle bodies on E-Bay but haven't made the jump yet. I like the look of the Mustang throttle bodies with the integrated IAC (idle air control) valve but I wonder if the idle air control valve is to big to fit into the Mercedes intake. I have also looked at the throttle bodies on the 4.6 ford trucks on ebay. It looks like these throttle bodies have the IAC implemented on an elbow that sits underneith the throttle body. I am thinking about ebaying one of the mustang 65m throttle bodies with a IAC and TPS and removing the IAC valve and covering the holes in the TB with a small scrap metal plate if the IAC valve proves to be too big.
I am open to any TPS suggestions. I have my whole intake apart and don't really want to put it back together only to take it apart again.
Thank you for the PM to the new Megasquirt thread!
'74 & '78 450 SEL
Discussion Starter · #5 ·
At this point I've decided NOT to get the whole throttle body unit from a different application but to use the existing TB and adapt a different TPS to it (or somewhere on the throttle linkage). I've acquired several used TPS's and am now mocking up a few variations along these lines to see what will work the best.
It looks as if 'jon' in post #3 is thinking the same thing.
I will (I swear) post pictures this weekend.
1980 450slc
I think Jon was refering to finishing soldering and assembeling the megasquirt board and has it working on the bench with the stimulator which is quite an accomplishment (I hated soldering those 4 little transistors). Congratulations! If he has a runing car this would be too much for me to bear as I have over a year into mine:)
I have a big hump on my throttle body behind the throttle switch which interfears with trying to adapt another TPS.
Can I ask why you decided to abandon the Ford throttle body? For me the cost of the Mustang throttle body and not knowing it is going to work is prohibitive.
While you guys are working on TPS's remember that the actual range of movement and the start and stop points of the TPS are not signifigant to megasquirt. Megatune has a real nice TPS range adjustment feature where you sit in your car with the gas pedal out and you just hit a button in megatune telling it that the TPS is at idle. Then you put the gas pedal to the floor and hit another button telling megatune that you are at WOT (wide open throttle) it then figures out everything from this. You can even have the wiring on the TPS backwards and megatune will work.
If you decide to go with a off the shelf potentiometer (variable resistor) the only thing you need to look out for is that the potentiometer is "linear taper" and not "audio taper". "Audio Taper" potentiometers change resistance exponentially with the movement of the shaft and a linear tapper potentiometer changes resistance linearly. I had a radioshack 10K potentiometer working but the cheap stamped sheet metal nut proved to be too flimsey. Maybe I will try e-bay'ing a quality built potentiometer.
Don't get too hung up on the TPS issue. My engine was running very nicely without any TPS enrichment at all. The TPS enrichment "fine" tunes the AFR for maximum power during acceleration. Without TPS (acceleration) enrichment you will still be miles ahead of the CIS injection system which could never get in the same ballpark of this type of fine AFR tuning. We are talking about tuning a few tenths of a point of AFR. CIS would be real lucky to get with in 4 or 5 points of stoich (14.7AFR). The main variables for tuning megasquirt are manafold vacuum (MAP) and RPM. TPS is is a very minor variable in comparison.
Making the fuel rails is just a matter of drilling holes in the right place and not breaking a drill bit off in the process. If you guys get stuck on the fuel rails let me know. I would be happy to drill a set of rails for you if you wanted to send me the fuel rail stock and pay for shipping both ways. The only cravet is I could make no guarentee that they would work on your vehicle. I would like to see you guys progress so you can tell me where to mount the relay board in the engine bay:)
Hbar, I would really like to see your pictures but don't sweat getting them up. There are only so many hours in the week and personally I would rather spend them working on my install than messing around with trying to figure out where to host the pictures.
· W123 Moderator
Hi Guys,
I so far have only just finished building the megasquirt. I still have to modify it for PWM Idle Control as that is what is used on the later Mercedes which has the idle control box next to the abs brain that keeps breaking ( my father is on his third one on a car that has down less than 50,000 miles from new). I have got all the bits to the tps on the stock throttle body, tps from an 86 Crown Vic the throttle body shaft from the Crown Vic and the original Mercedes throttle body with a tps switch on ( W126 is where mine came from, I also picked up a complete inlet manifold so I can check clearance with pulling my car to bits). Just need to mount ford tps using Ali plate some screws and the cut down shaft to provide the correct key for the ford tps.
The ilde control is foxing me a bit at the moment as the later car uses feed from manifold and base of cis injectors to do idle.
Still waiting for the fuel rails and the very expensive drill bit that drilss the correct hole. SO fuel rails still need to be built but the plus piont is that all the cis heads seem to have the same injector spacing (not all the same but some offset).
Anyway enough rambling, hopefully will have time Friday and Saturday to work on fabing the tps stuff. As I have to replumb my pool this weekend too.
See you all later
Jon White
PS oughtsix where are you located ?
1980 450slc
Hello Jon,
I live in Redmond Oregon (Outside of Bend OR) and fortunately it isn't pool weather here yet. There is always something broken on our above ground pool every year but fortunately I have a week or two before I have to figure out what the problem and expense will be this year.
My first IAC valve was a 5 foot piece of vinyl tubing, a plastic barbed T fitting and a 1/2" ball valve that sat in the passenger compartment with me. They were all extra parts I had lying around. I adjusted the ballvalve by hand while I was trying to get the engine to turn over and stay running for the first time.:) (Truthfully the ball valve was a later refinement for my first trip around the block as I just put my thumb over the tubing the first time I got the engine to stay running to lower the idle RPM.:D)
Basically my approach was to rig things to get the engine running then come back to figure out the finer points of the engineering later. By taking this approach I could get my engine running without worrying about wether my IAC solution was working and I was able to get my IAC working without worrying about whether the rest of the engine was running smoothly or not. I tried to isolate the variables and work on one problem at a time instead of trying to get everything to work together the first turn of the ignition key. Kind of like not doing the fuel and timing at the same time.
I still don't have an airfilter solution yet.
My intake has two ports on it for Idle control. Both of these fed through tubing from the mechanically tempature controlled IAC valve and an extra small aluminum manifold that also carried the cold start injector for my CIS system. I am still using this stock idle controll system with the cold start injector still in there but disconnected from fuel.
P.S. Cool aquisition of the fuel injector pocket reamer. I found out about them after I built my rail and wish I had one. They are spendy but I am sure it will be worth it!
'74 & '78 450 SEL
Discussion Starter · #10 ·
LINKS TO PICTURES
Top of engine torn down:
http://s209.photobucket.com/albums/bb135/hbarcat/th_IMG_0008.jpg
CIS components. You can see the auxilliary air bypass valve on top of the water passage on the front of the intake:
http://s209.photobucket.com/albums/bb135/hbarcat/th_MBIntake1.jpg
These are the fuel rails that I'll be using from an early 70's Mercedes with the Bosch D-jetronic EFI:
http://s209.photobucket.com/albums/bb135/hbarcat/th_MBFuelRails1.jpg
An injector and rail boss; I'll need to make a tight connection between these two with a short section of hi-pressure fuel line: http://s209.photobucket.com/albums/bb135/hbarcat/th_InjectorAndRailBoss1.jpg
The stock mechanical fuel injector with its sleeve and o-ring from the Bosch CIS K-jetronic:
http://s209.photobucket.com/albums/bb135/hbarcat/th_BoschMechFuelInj.jpg
New Bosch fuel pump and filter with assorted bracketry (same as stock pump and filter but it needed replacing anyway): http://s209.photobucket.com/albums/bb135/hbarcat/th_FuelPmpwFilter.jpg
The MegaSquirt2 with relay board and wiring: http://s209.photobucket.com/albums/bb135/hbarcat/th_MSQ2nRLYnWIR.jpg
Innovate WB O2 sensor and controller:
http://s209.photobucket.com/albums/bb135/hbarcat/th_O2SensAndControl.jpg
83 300d turbo, 79 c123 AMG
Very cool.
For those attempting this, what is the approximate cost of the entire modification? I have K-Jet with aftermarket Lambda on my 79 280ce M110(european import)and it is starting to show its age. I really don't want to start dumping hundreds of dollars on OE parts and still have fuel issues. I am also very interested in hearing about performance/mileage improvements.
'74 & '78 450 SEL
Discussion Starter · #15 ·
The cost of the Megasquirt unit itself is minimal, about $400 prebuilt and tested for you but the "miscellaneous" parts such as sensors, fuel injectors, wiring etc.. can be cheap if you already have them or can get them used, to many hundreds of dollars more if you need to purchase them.
I've got about $1000 invested already and will probably spend a few hundred dollars more by the time it's done, but I'm doing the "full" conversion to a crank sensor Distributorless Ignition system.
A frugal person could probably do the entire fuel only conversion for less than $500 finished.
More info:
1980 450slc
My father has been ill and I went to visit him this weekend so I have made no progress on my install but I have started to put together a website. Here is a link to my INCOMPLETE bill of materials to help you with some idea on cost.
I will continue to update my website as time permits.
1980 450slc
I was able to spend some time on my install this weekend. I got everything back together and wired everything with the relay board. I pulled out a lot of stock ignition wiring and cleaned things up. I spent a good hour trying to get her started back up and it would run for 15 seconds then die. This frustraited me for a while then I remembered having the same problem when I initially got her running.
TIP: If you are using the stock fuel relay it will not energize unless the system detects the engine is running. I.e. No Tach = No fuel = No go!
When you turn the ignition key the fuel relay energizes the fuel pump for a moment then turns off power to the pump. When the fuel relay circuit detects the engine is running it energizes the fuel pump again. The green/yellow wire from the bosch ignition box needs to be connected the the green wire and green/yellow wire from the diagnostic connector.
Why don't you use the Megasquirt fuel pump relay control?
1980 450slc
The stock fuel pump relay circuit works very well and everything is already wired in with the proper fuses etc. The only thing you have to make sure of is that you feed a tach signal to one wire in the engine bay. This can be a tach signal from the stock Bosch ignition, the Ignition out line from Megasquirt or the tach out from the MSD. Either way it saved a lot of wiring using the stock fuel relay and has proven to be reliable. I just needed to refresh my memory from over a year ago about the tach signal. The Tach signal also feeds the instrument cluster tachometer.
I pulled the majority of the stock ignition wiring to straighten things up. I am running a MSD6AL for ignition. This made the stock ceramic low resistance resistors mounted on the driverside fender surperflous. The MSD drives the coil directly and does not need any external resistance. Under the mounting point for the resistors on the driver side fender there is a 2 post terminal strip. On one of the posts is a green/yellow wire and a green wire. I believe the green/yellow is the tach signal for the dash tachometer. I believe the green wire is the tach signal for the fuel relay circuit. I believe the green/yellow wire from the Bosch ignition box was originally connected here. I just needed to reconnect it after my cleanup.
The fuel relay circuit is completely independent of the K-Jetronic CPU. I have my K-Jetronic module completely removed and the fuel relay circuit still functions as it should. My theory is that the tach signal detection is actually within the fuel pump relay itself but it has been quite a while since I looked at this schematic.
I am considering removing the bosch ignition box altogether to further simplify things. This would leave megasquirt reading the tach signal directly from the distributor (VR I believe). But for right now the Bosch box is doing a good job of conditioning the signal and with the MSD driving the coil (or megasquirt directly) there is really no load on the bosch box. By my thinking this means it should last a long time as the power transistors are switching a very small fraction of the current they were designed for.
Any way it is nice to have the old girl back on the road again! I drove her to work for the first time in about two years. She was running over a year ago and running well a few months ago but the rats nest wiring was pretty bad. Installing the MegaSquirt relay board made a huge difference in the cleanliness of the install. I also feel much much better about the reliability as everything is well laid out and tight.
I hope to post some pictures and commentary about the wiring on my website later on this week. I will also post some gas mileage figures as they start adding up here in this forum.
1 - 20 of 136 Posts
