1995 MBZ E220, 5 speed manual
On my 1995 RHD E220, I need to replace the 5 speed shift knob, as it is pretty worn out on top.
Can someone tell me if this is a screw on type knob, or do you have to replace the knob with the lever that goes down to the tranny?
The car is in India, so I do not have a chance to play around with it and figure it out.
Thanks for the help.
Mercedes 300te
I think those are the shaft type if i remember it right. I could be wrong.. You can always buy a new factory one. Or do you want an aftermarket one?
Shift Knob
I was thinking of going with a wood finish with the emblem on top. The problem is I do not know if its just a screw on shift knob or the entire shaft has to be replaced?
