1998 E320 4matic wagon
I saw posts recommending OEMparts as a potential sourse for a cheaper replacement key, but their web site appears to be extinct. Am I stuck with the dealer? Hoen Mercedes parts dept is telling me that there is a 90% chance the new key will work but if it doesn't I can not return the $200 key and I'll then need to upgrade the ignition system.
Is this true?
2003 Mercedes Benz E500
Be careful with...
your terminology... a "replacement" key makes all other existing keys for the car invalid/inoperable. An "additional" key [I believe up to 8 keys] keeps the original coding intact.
The dealer ordered one [additional key] for my '97 E420 and it worked fine, and I was given no such warning at all...
Good luck,
JR
2002 ML320
Yes you are stuck with the dealer for the key.
Unless your car has been assigned 8 keys already it will work. If it has been assigned 8 keys you will have to replace the system.
True that you cannot return the key as it is programmed and considered useless on any other vehicle but yours.
OK
It is an additional, not replacement. I was thinking replacement as in replacing a lost one.
BK
