1 - 1 of 1 Posts
'99 Range Rover ~ '01 Land Rover ~ '06 Mercedes e350 ~ '76 Mercedes 280C
My sons '03 c240 is stuck in 1st gear and when scanned it pointed to the common failed conductor plate in the trans. A new kit was ordered and installed with new 6 liters of fluid. It's still not shifting, check engine light and no response from the WS switch....all indicative of needing an erase of codes and reset (of which we were unaware of being necessary).....
Thoughts...... Likely a code issue? Should I buy a scanner/reader or is it dealer stuff? If buying one.... recommendations? I have my DD '06 e350 and I'm old school so I thought maybe I should just buy a scanner since this later model stuff seems to need it.
1 - 1 of 1 Posts
