I tried to make this post short, but its not at all..Just a little warning
After having a clunking noise coming from the rear of my suspension, I decided to replace the rear shocks on my car (1996 S600).I was lucky to come across a S500 with ADS at a junkyard during my vacation, so I had to get up early, buy some tools, drive 45min and remove them and send them back home so I had a spare to play around. I saw them new online in stock for about $450-$550. Long story short and after making about 10 orders with various vendors and various part numbers (1403209913, 1403209613, 1403208913, etc), a lot of calls, I found out that they do not exist anymore and are replaced by part number 320-96-13-26 with a new price tag of about $1000 to $1200. Once I found that out, I definitely decided to replace the bottom bushings and top mount/absorber on mine own and not pay over $2000 for new ones.
I have seen a thread where some people successfully replaced bottom bushing with Lemforder control arm bushings PN# 31121124622. This requires cutting a metal jacket and shaving the rubber so I tried to find a different solution. I decided to go with a polyurethane bushing for bottom of the shock.
After a lot of research, the best option I found was this bushing (PF99-104) from PowerflexUsa that has outer diameter of 35mm and its $28, with full dimensions shown below.
Given that the length of a bushing housing at the bottom of my stock shock is about 31mm-32mm I had to cut “G” part of the Powerflex bushing to be about 16mm since I need 2 on each side (16x2=32mm). The lip “H” is 7mm so that gives me total length of the entire bushing once pressed in of about 46mm (G-32 + H-14), if I cut it where lip “H” sits exactly on the outer edge of the bushing housing. You can leave “G” part little longer and have exact length of 52mm (length of the inside sleeve) but I didn’t do that, I left about 2-3mm left on each side and used a washer.
Talking about the metal sleeve inside of the bushing, that was another problem since the sleeve that comes with the bushing PF99-104 is meant for an 8mm bolt and mine is 12mm, and its also much longer than 52mm. I had to find a new sleeve that’s 52mm long (to match stock sleeve length), with outside diameter of 16mm and inside diameter of 12mm to fit inside powerflex bushing and to accommodate the stock bolt. I couldn’t find it anywhere so I had to custom order it and have it made from somebody on ebay. It costed me $18 per sleeve.
Left is what was inside of the stock shock bushing, and to the right is a sleeve I ordered.
Ok, so now how I did it…
I first I pressed out the stock bushing with a 12ton press with ease, using a 1 ½ socket:
I just pushed against the inner sleeve an it popped out on the other side, it popped twice, first time to break the metal seal/lip and the second time when it was totally free. Then I had to flip it to the other side, and pop the other side since metal seal/lip was still there and some of the bushing was still there…
First side successfully popped…
Other side with the lip/seal and some of the bushing left inside.
Like I said, I just re inserted original metal sleeve from the other side and pushed through the metal seal/lip and got everything out.
Other side being popped like this:
