you can release the top of the rear shock thru the trunk. remove the floor liner, the plastic tray that covers the electrics, then the plastic strip right behind the seat that has the tie down loops on either side, then with the back seats down, pull out the plastic rivets that hold the side trunk liner and peel it toward the center of the trunk. that will expose the top of the rear shock. remove the nuts and rubber washer. next go underneath the car and remove the bottom nuts and remove the shock. I have never done the fronts but it is pretty straight forward. do the tops first etc.
