Re:
There are two types of shift knobs available. Post 95 models can just upgrade the top part of the knob. Pre 95 models are one piece and have the knob and metal stem attached together, so they have to be replaced together.
Assuming your is a one piece and the replacement you've bought is also one piece
Place car in the lowest gear (usually 2) and then press down VERY hard whilst rotating anti-clockwise.
The knob will release with the stem. Fitting is reverse of the above.
The difficult part of the operation is pressing down hard enough to break the resistance of the spring. I had to use my full body weight whilst pushing.
Good luck[
Good luck[
