I know that it is probably not the ideal way to replace it - But can you replace the eccentric bolt with the suspension together? Meaning, can I support the control arm with a jack and slide the bolt out and slide a new one in? If so, is there one of the mounts(front/back) that is preferable/easier to accomplish this?
I am rebuilding my suspension and am to the point of re-installing everything and just found out that someone cross-threaded one of the bolts in the past. I've looked for a die to re-cut the threads, but no one local has one that size(this late at night). I would really like to get everything back together so I can get the car out of my parents garage. I know that I could just take everything back apart once I get a new bolt, but I really would like to not have to go through all this again. So my idea/hope is to rebuild everything now with the bad bolt and just replace it in a couple of days when I can get a new bolt. Not ideal, but will it work?
Any ideas?
Any ideas?
