Hi,
Any guys out here have DIY for removing the tele system (to free space in the arm compartment) and the lighter compartment (to replace the yellow bulb in there with LED...
Please advice. :)
2002 CLK 55 AMG
im not sure about the phone system, but you can remove the lighter compartment by pulling the trim around the shifter off "from the front" after you remove that you can unplug the wires for the window controls and then remove the two screws that hold the lighter compartment down. now you can pull it off, you have to pull kinda hard but not two hard because you could rip the wire for the lighter compartment.
Hopes & Dreams
The phone in the center console is extremely easy to remove, it's pretty straight forward. Trace the wiring to its connector, and unplug...also, on the top tray, unscrew the screws/bolts holding it in place.
I did this a long time ago so I don't remember details but all it takes is a good look and you'll figure it out.
