I can't believe I am stuck at the very beginning of my adventure... but I am. I am trying to remove the right valve cover but there are two vacuum lines in the way. The purple one goes to the distributor and the green one goes to the throttle body. They both go into a pod in front of the battery.
I've looked at pictures of other people's 1974 450SL engines and I don't see these two lines going over the valve cover at all. Are mine routed incorrectly?
How do I disconnect them to get the valve cover off?
Thanks!!
I just pulled mine off carefully when working on the motor. I think they are probably wrongly routed as mine go round the front rather than over the top. Make sure you keep track of what goes where - I take multiple pics before removing anything!
Thanks for that. I removed the vacuum lines at the pod. Now I have the cover off and here is what the guides look like. They are a uniform golden brown. I guess they need to be replaced?
Andy, before you go at it you ought to rotate the engine by hand to meause the chain stretch... And then yes, onto replacing guides, sprockets, chain and the tensioner as Aussiemerc advised. Earlier tonight I created a thread how to do it based on my experience last week.
No need to remove the accessories Andy as long as you can reach the 27mm nut and rotate the engine, the flywheel with angles is visible at all times.
About this Discussion
3 Participants
miko1aj
Mercedes-Benz Forum
Full Forum Listing
