4xpaws said:
Any one know how you remove the A pillar trim and the vertical seat belt pillar trim in the cab?
Never had much luck with trim in the past - I always discover how it should've been removed once I've got it off and broken all the hidden fixings.
Hi 4xpaws,
I've never removed the seat belt pillar but I have removed the A pillar several times. You just have to pull on the lip closest to the head lining, once you have it off there are 3 or 4 plastic clips on the end nearest the dashboard and 2 or 3 metal clips that locate in the roof above the door, when you put the trim back on insert the metal clips in the roof first and then clip the trim onto them otherwise you'll never get it back on. I will warn you though I have had to buy new clips for mine because the plastic ones brake and the metal ones bend :crybaby2:
Although having said that my trim has been off so many times yours might be ok, just be careful.
Good luck!
Benz Bling
